after engine warmed up won't idle,
Old May 1, 2017 | 06:39 AM
beanie's Avatar
Default after engine warmed up won't idle,
runs & sounds good when cold once warmed up , runs loosey.set idle jet out 2 turn ran good till warmed up, I'm thinking electronics or valves setting??? or choke stuck out alittle but cleaned that out real well. The eng. has a popping sound when warmed up. Also can I get a free repear manual online???
Old May 2, 2017 | 01:52 AM
Set the valves anyway. Never fiddle with the idle mixture screw, it was set at the factory and won't need altering unless you have done major tuning work. Too late now so, once you have set the valves, get the engine warm and screw the mixture screw in/out until it runs better. My guess would be in.
Old May 2, 2017 | 05:34 AM
beanie's Avatar
Thumbs up
Thanks for the reply I will do that. thanks again!
tylersherman12
Apr 26, 2017 07:45 PM
STCxSeabass
Utility ATVs
Apr 24, 2017 09:07 PM
KQ2492
Apr 6, 2017 05:06 PM
Dale Lunsford
Apr 5, 2017 04:23 PM
bandit01
Polaris Side by Sides
12
Feb 17, 2017 03:52 PM
