BOG OUT PROBLEM 2000 Polaris Trailblazer 250 2x4
Hey guys i was wondering if you guys could help me out a lil with my 2000 Polaris Trailblazer 250. I cleaned the carb inside and out all the fuel lines are ok and intake is ok, and compression is good. But when i start it and start going and try to push it to power it bogs out, it doesn't quite turn off but i cant press down the gas right away and go. Any leads..?
Plus most times just "cleaning" a carb is a waste of time if worn parts are left in. Get a good carb kit and eliminate the carb as a problem. 1996-2000 Polaris 250 Trail Blazer Carb Carburetor Repair Kit 03-405 | eBay That is after you recheck compression. 100 psi is right at the bottom as far as the manual calls for and even that low you can still have problems. Wouldn't hurt to check for leaks and spray a little wd 40 around the intake manifold and base gasket and see if the engine rpms change.
Peeps
Mar 24, 2000 12:27 AM
