yamaha moto 4 350
Old May 14, 2017 | 08:53 PM
help yamaha's Avatar
Default yamaha moto 4 350
i have a 1989 yamaha moto 4 350 not have the power it should builds up alot of pressure in crank case ha wrong air filter where should i start
Old May 15, 2017 | 02:56 AM
The breathers are open pipes into the airbox so, if they are not blocked off, there won't be any "build up" of pressure. Because it is a single cylinder engine, the breather has to puff out 350cc of air on the down stroke, and suck in 350cc on the up stroke, so will be puffing a lot of air in and out each rev, this is normal.
Set the valves, and if this doesn't increase performance, do a compression test, should be over 90 psi. If that is OK, you may need to re-set the carb jets to suit the non standard air filter, or get an original filter set up.
ManuelCarrillo3
Oct 24, 2016 08:30 PM
merc1100sc
Sep 9, 2016 11:35 AM
Simon81
Aug 19, 2016 11:08 AM
dark_knight8921
Aug 13, 2016 11:56 PM
