Where to find the vin number for Yamaha Timberwolf
I have a used Timberwolf the only numbers found were stamped on the engine were 1500cm3
Is this a 250 or 230?
Where is the serial number located to find the make and model?
150cm3 would make it a 150cc. On most Yams the frame number is on the lower frame tube in front of the LH footrest, but I have never found it there yet. Dealers seem to know all they need for parts, from the code on a white sticker on the frame, under the seat.
Technically it is a 229cc but Yamaha calls it a 250cc. Same displacement as the Honda Recon, which is also called a 250. 1500cm3(1.5L), that doesn't sound like quite enough oil. Generally oil is sold in U.S. quarts, which is slightly less than a liter. I don't think I've seen any full-size quad that required less than 2 quarts. Most take more than that.
MikeyBoyesq
May 3, 2017 09:55 AM
