00' - 01' sportsman 500 ho
Old Jun 3, 2017 | 10:25 PM
RHL's Avatar
RHL
Default 00' - 01' sportsman 500 ho
I have an 00' bike that the motor went bad in and I put a motor from an 01' in it I have gotten everything to work except I can't figure out how to wire the regulator in. Anybody have any suggestions on how that works with the ignition?
Old Jun 4, 2017 | 08:57 AM
Did you use the original 2000 stator and wiring harness or the later model 2001? Makes a difference on models. If you need a manual with wiring diagrams,this one should show your 2000 and the 2001. https://www.tradebit.com/filedetail....service-manual
Old Jun 4, 2017 | 04:02 PM
RHL's Avatar
RHL
Smile
Hi thanks for responding. I used the old stator and harness. So I have my yellow and yellow/red connected directly to it and my brown runs off to the ground. So do I need to run my red through my ignition switch or can I send it straight to the battery to charge? The problem is that my fan will not kick on so the bike over heats. I put a new temp sensor on it and a new thermostat and I am pulling -11 volts on the power wire running to the fan. Do u think I should hard wire a switch for the fan or is there something I am missing that I could do so that it is done correctly? I'm not going nuts on this it is the bike I use for being an ambulance chaser while my kids are learning how to ride. Thanks again for your time and knowledge
Old Jun 4, 2017 | 04:03 PM
RHL's Avatar
RHL
Also I got the schematic u linked to and it was a great help thanks
cornermike
Aug 21, 2016 05:44 PM
instagramfinggaz
Aug 14, 2016 03:15 PM
Ipmcelroy
Jul 23, 2016 01:48 PM
Zephead98
Jul 22, 2016 04:27 PM
PolarisPower500
May 17, 2015 02:28 PM
