93 king quad need help badly plz !
Old Jun 29, 2017 | 03:49 PM
KQ2492's Avatar
Default 93 king quad need help badly plz !
My 93 kq 300
It takes forever to start I have to hold the throttle mid to wide open and it chugs then starts
.sometimes the plug is wet with fuel sometimes its not
I've cleaned the carb 3 times with a wire poking through all holes
I've checked spark its a bright color blue ish
I've checked for air leaked and tightend everything
Its always been hard to start but now its gotten so bad
I have to hold the button and push throttle over and over and it will chug chug and eventually fire up
Now when its started it runs amazing no bogging backfire nothing like that ..
While running if I shut it off and press start it fires right up
But if while running I shut it off and let it sit longer then 5 mins it goes right back to hard starting
I forgot to mention I have checked choke cable and it is working properly
Old Jun 30, 2017 | 02:50 AM
Check compression, low compression can give poor cold starting. This can be caused by valve clearances being too tight, so check them. Other possibility is a little fuel getting past the float needle, not sure how the 93 models work, but most Suzukis stop fuel flow to the carb when the engine stops, but if fuel in the pipe gets past the float needle, it gives a very rich mixture, and will only start with a wide open throttle.
Old Jun 30, 2017 | 01:46 PM
KQ2492's Avatar
I opened the tab on the spark plug a little bit and it seems to be starting a lot better don't know why
I'll update after the weekend might just be w coincidence
Old Jun 30, 2017 | 10:54 PM
KQ2492's Avatar
Nvm that did not help it is very hard to start cold and hot but runs great once running
Old Jul 1, 2017 | 07:23 AM
LT80's Avatar
LT80 Expert
So you haven't checked the valves and comp?
