bigger pistons?
Old Apr 18, 2001 | 10:21 PM
hellcat241's Avatar
i was wondering how big of a piston could i get without resleeving. also does resleeving mean the same thing as bore? will a bigger piston give me more power? and if it helps ive got a 300ex. thanks for the help
Old Apr 18, 2001 | 10:39 PM
adamsmith's Avatar
Go to Powroll.com, and you can see all their kits. I am pretty sure they show you what you can do with a stock sleeve and then what you can do with a big bore sleeve and or a stroker.
Boring is different from sleeving. Sleeving becomes necessary when you have bored your cylinder to the max that the stock sleeve will allow. Like my 440 sleeve is thicker than the stock 400EX sleeve. Also, with the 400EXs and 300EXs you can get a tapered sleeve or a sleeve that is the same thickness top to bottom. If you go with a non tapered sleeve you will also have to get your cases bored to allow for it.
Adam Smith
99 400EX
exmotocrosser
Sep 13, 2019 06:12 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
dunerv8
Technical and How-To Articles
Sep 14, 2015 10:11 AM
nastyblaster100
Sep 13, 2015 01:19 PM
