headlights wont come on/2011 honda rancher
Old Sep 11, 2017 | 03:14 PM
cserini3's Avatar
Default headlights wont come on/2011 honda rancher
with the key on the headlights or taillights wont come on. if i switch the key off all lights work and come on. i have replaced the ignition and put a new battery in it. other than that i have not done anything else electrical to it.
Old Sep 12, 2017 | 02:16 AM
Seems like you have fitted a wrong ignition switch. This switch cuts power to everything connected to the battery except the voltage regulator on most bikes. However the 420 electrics are insanely complex, with two relays in the battery box as well as the solenoid, and an extra tiny voltage regulator, as well as the EFI system. It is just possible one of those relays is feeding power back through the system with ignition off. If you are sure the ignition switch is OK, try swapping the relays round, the fault will change to something else if one of them is bad.
bookman35
Dec 30, 2020 07:52 PM
Ohio al
Aug 22, 2017 07:03 PM
SuperMidget
Aug 3, 2017 09:38 PM
46 cub
Jul 27, 2017 10:41 PM
back41
Jun 20, 2017 09:21 AM
