Bombardier 2005 500 Traxter
Old Oct 2, 2017 | 05:04 PM
Nick3405's Avatar
Question Bombardier 2005 500 Traxter
Battery was dead so pull started quad and road it for a day with no prob. Next day it would idle fine but with acceleration it would sputter,backfire and lose power. Got it home and put a new battery in and now nothing when key is turned on. Battery is fully chged. What can it be ? Please help ! Thanks
Old Oct 2, 2017 | 06:01 PM
Nick3405's Avatar
So I pulled the 20 A fuse to the MPEM which was blown and turned the key and it imed blew again. Could it be the MPEM ? Hopefully something else ? Please help.
Old Oct 2, 2017 | 07:41 PM
electromatic's Avatar
Hey Nick< have repaired several of the Traxter MPEM's from that vintage. They die when jumped of the battery is replaces and cross connected for an instant. Blowing the 20 A fuse is a indicated of the internal diode in the MPEM being shorted. I cut open the MPEM case and replace the damaged components then silicone it back together. I have done several of them including my own and they have all worked. Last I looked the MPEM is about $1500 if you can find one. My phone id 770 2512 40 80. Burl
Old Jan 9, 2018 | 10:57 AM
Eddie63's Avatar
Burl,I have question for you please.I'm helping my brother in law on a john deere buck. Wich is a barmbarier trax. It seems to be firing but want try to start. Put Chem tool in spark plug hole and it didn't fire. Thanks eddie. 806 270 1320
Old Jan 9, 2018 | 11:25 AM
Eddie63's Avatar
Old Jan 9, 2018 | 07:18 PM
Default Traxter
Eddie 63,
Two things make a engine start fuel and spark,
First check to see that you have spark by pulling the plug lead off and putting a plug in the boot then holding the electrode of the plug grounded to the engine. When you crank it you should see a spark.
If it cranks and you see a spark the problem is probably not electrical.
most likely it is fuel system or carb.
On the other hand if it does nothing and it started doing that after the battery went dead and was jumped off the computer (MPEM) may be fried. I can fix the large two plug computers for this and only this problem.
I hope this helps.
Old Jan 9, 2018 | 08:32 PM
McCoy73's Avatar
Burl; I have a 2003 Bomadaire 650 Dx and this thing runs hard; but smokes. Had top end rebuilt and it still smokes. Smoked off the showroom floor. Can not figure out why. Any sudgestions?
Thanks
McCoy73
Old Jan 9, 2018 | 09:28 PM
Sorry But I have no idea why it would smoke. is your fuel contaminated with diesel?
Old Jan 10, 2018 | 11:48 AM
McCoy73's Avatar
No. Fresh out of the pump. Thanks for responding though.
Old Jan 10, 2018 | 04:57 PM
McCoy73 .
First make certain that the crankcase is not overfull, if it is to high it may smoke.
My first suspicion would be the valve stem seals. If they smoked before and they did not change them in the top end work that would be the oil route to the cylinder.
My next would be the piston ring gap. Even with new rings if the cylinder is oversize the end gap may be large.
