Taotao 125 brake not working so will not start.
Old Oct 15, 2017 | 09:49 AM
Duckmenje's Avatar
Default Taotao 125 brake not working so will not start.
I bought my daughter a taotao 125 and it's been running fine. Last weekend I went to start it up for her and worked fine. I slide the back around and it stalled. I went to put the brake back on and the rear light did not come on. I also noticed that when the brake is applied the neutral light goes out. So it will not start now. Checked bulb and wiring connections and all appear good. And ideas?? I know she wants to ride.
Old Oct 16, 2017 | 02:51 AM
Check for a bad earth, when lights start going out because you turn something else on, it is usually an earth fault. Also check main positive wire from battery to ignition switch.
Old Jan 4, 2020 | 04:22 PM
Austinlee23's Avatar
I have one that's doing something similar when I apply brake to start the neutral light goes out and wont start
Old Jan 5, 2020 | 03:22 AM
I forgot to mention the most obvious, a flat battery, otherwise it is almost certain to be the above mentioned bad connections on main wires.
Dogger11
1) Engine problems..
11
Apr 27, 2020 09:25 PM
Duckmenje
Oct 27, 2019 09:25 AM
jomiller97
11
Jul 13, 2018 07:58 AM
Griegojgg
Jun 4, 2017 09:37 AM
Griegojgg
Mar 24, 2017 02:54 PM
