Tao Tao 110 will not start
Old Oct 19, 2017 | 01:18 PM
sgcook70's Avatar
Default Tao Tao 110 will not start
It will not start at all not eve turn over. The battery is fully charged and it has a new spark plug. Can someone help? My daughter just got a used one and it has been running fine for the last few weeks. The oil was changed before we brought it home.
Old Oct 19, 2017 | 02:36 PM
DirtDevil101's Avatar
Not turning over could be a number of things. Do you hear anything when you try to start it? If nothing then it's a bad relay or blown fuse.
If you hear something what does it sound like?
Old Oct 19, 2017 | 02:59 PM
sgcook70's Avatar
I hear nothing. You push the switch an nothing try to give it gas and nothing. It make no sound. I do not have a manual so where would I find the rely switch or the fuse.
sgcook70's Avatar
I hear nothing. You push the switch and nothing try to give it gas and nothing. It make no sound. I do not have a manual so where would I find the rely switch or the fuse.
Old Oct 20, 2017 | 07:47 AM
If you can't find a wiring diagram online (I'm pretty sure they are out there), then you can visually trace the wires coming off the battery (you may need to remove some plastic to clearly see the electrical wiring). The relay will usually look like a little box.
If you don't have one yet, I highly suggest getting an ohms/voltage reader. They are cheap and will be you most important tool in tracking down electrical faults...
cornermike
Aug 21, 2016 05:44 PM
chinlucd
Aug 17, 2016 10:54 AM
Libertynow
Aug 14, 2016 05:29 PM
Libertynow
Technical and How-To Articles
Aug 13, 2016 01:55 PM
bbm1019
Aug 5, 2016 09:32 AM
