2001 350es shifting problem
yesterday my 350 refused to shift this has probably happened twice since new, I tried rocking it which usually helps but not this time, used emergency shifter to get it down from 4 to neutral. problem didn't come back after that but im worried about getting out and having this problem. I wasn't smart enough to put shift tool away and lost it in the snow somewhere.
The problem can be anything in the system, faulty shift motor, angle sensor, or shift buttons being the most common. If it is a one off fault, get yourself a 12mm ring spanner and put that in the toolbox, you can "hand change" using that if you get problems again.
thanks merrymen
heading out this morning and will take wrench as backup, when I shift it was hitting hard but not engaging. looks like a summer repair job -6c now was -14c yesterday morning
