2001 350es shifting problem
Old Nov 9, 2017 | 08:22 AM
mr p rick's Avatar
Default 2001 350es shifting problem
yesterday my 350 refused to shift this has probably happened twice since new, I tried rocking it which usually helps but not this time, used emergency shifter to get it down from 4 to neutral. problem didn't come back after that but im worried about getting out and having this problem. I wasn't smart enough to put shift tool away and lost it in the snow somewhere.
Old Nov 10, 2017 | 03:11 AM
The problem can be anything in the system, faulty shift motor, angle sensor, or shift buttons being the most common. If it is a one off fault, get yourself a 12mm ring spanner and put that in the toolbox, you can "hand change" using that if you get problems again.
Old Nov 10, 2017 | 06:21 AM
mr p rick's Avatar
thanks merrymen
heading out this morning and will take wrench as backup, when I shift it was hitting hard but not engaging. looks like a summer repair job -6c now was -14c yesterday morning
Old Nov 12, 2017 | 11:16 AM
mr p rick's Avatar
12 mm spanner now in tool box, but didn't have a problem shifting this weekend
