hand and thumb warmers 2004 Sportsman 500
Old 11-26-2017, 09:47 AM
ColoradoMike's Avatar
Default hand and thumb warmers 2004 Sportsman 500
Both hand and thumb warmers quit working. How do I troubleshoot?
Old 11-26-2017, 11:22 AM
Work from the toggle or rocker switch wiring on down.Make sure the switch has voltage and ground wires are good. Hand warmers/ thumb warmers are usually tied into a red/white wire that's powered up when the ignition switch is on. Could be as simple as a circuit breaker faulty if so equipped,a ground or power wire fault or a fault in the switch itself.
Old 11-26-2017, 03:40 PM
Switches have voltage so checked leads coming out of the heater grid wrapped around the handlebars. Voltage there also but no heat. Found small break in the grid on both grips. Hope it is as simple as that.
Old 11-26-2017, 03:44 PM
Hopefully it's a simple repair. Small wires that can be easily damaged.
2002BlueBlaster
11-12-2017 10:11 AM
trbojet1
10-12-2017 04:33 PM
JRM
10-10-2017 10:49 AM
Rob86
09-29-2017 01:07 PM
Eddean
09-22-2017 10:19 AM
Quick Reply: hand and thumb warmers 2004 Sportsman 500
