hand and thumb warmers 2004 Sportsman 500
Work from the toggle or rocker switch wiring on down.Make sure the switch has voltage and ground wires are good. Hand warmers/ thumb warmers are usually tied into a red/white wire that's powered up when the ignition switch is on. Could be as simple as a circuit breaker faulty if so equipped,a ground or power wire fault or a fault in the switch itself.
Rob86
09-29-2017 01:07 PM
