Growling Noise in Transmission
Old Polaris Tech (or anyone else that can help me),
I've finally decided to fix the growling noise in my 2005 Sportsman 500 transmission after putting up with it for 1 year. Unfortunately, I can't seem to find anything obviously wrong and need some help to find the noise. Here's what I've done so far:
1.) Took off the front drive shaft. The growling noise continued, so I ruled out bad u-joints, front differential,...
2.) Took off both rear hubs, and inspected the bearings. They appear to be a little wore, but not that bad. The bearings rotate smoothly and I can't feel any rough spots that would cause a growling noise at high speed.
3.) Pulled the transmission, and split the case. Again, I can't see anything obviously wrong. The chain tensioner, pins, and spring were disassembled, but I think that happened when I split the case. None of the gears look bad and/or worn. I checked all of the 5 bearings that are visible, and none of them appear to be bad. When I rotate the trans by hand, I can hear a slight growl, but can't pinpoint where its coming from.
Any help and guidance finding this growl would be appreciated by anyone.
Thank you
Thank you
Polaris5
23
Jan 22, 2018 01:00 PM
