04 Sportsman 700 gauge cluster appears to have to no power. Blank Screen
Old Dec 26, 2017 | 04:59 PM
rumrummer48's Avatar
Default 04 Sportsman 700 gauge cluster appears to have to no power. Blank Screen
04 Sportsman 700 gauge cluster appears to have to no power. Everything else seems to be working fine. It was working fine the last time I ran it. It's sat for about a week. Turned the key on and nothing shows. Starts and runs fine. Any help would be greatly appreciated.
Old Dec 26, 2017 | 05:39 PM
Pull the spedo connector,open the snap cover and check that pins and wiring are ok. Should have 12 volts at all time on the red or orange/white depending on model. The cheap service manual has a spedo no display series of checks and pin tests that can help you either narrow it down to a wiring problem or a problem with in the spedo head itself.Polaris ATV Service Manuals PDF Download You don't say efi or carb,but both are listed.
Old Dec 26, 2017 | 06:03 PM
Ok I checked for power. All the wires and pins looked good. i had power at the red wire and the orangish-red/white wire. also had power at the yellow wire. There was some condensation behind the lens cover. Is it possible the there is moisture behind the display?
Old Dec 26, 2017 | 06:07 PM
Possible since you have power into the spedo. Some year models had problems on displays going blank.If you're so inclined you can try what the two posts show.Either that or 250 bucks on a new speedo.http://forums.atvconnection.com/pola...ml#post3232409
KA7OEI's blog: Repair of the speedometer on a Polaris Sportsman 500 4-wheeler
Old Dec 27, 2017 | 08:03 PM
Took it apart and found moisture around the inside. I dried it out overnight and then hit it with the hairdryer this morning. Works great now.
200es
Oct 21, 2016 08:19 AM
cswiger
Sep 2, 2014 01:11 PM
surfcaster
Jun 9, 2013 07:27 AM
Genocite
Jul 31, 2008 01:43 AM
boss400
Nov 18, 2005 09:36 PM
