Arctic Cat 2017 500 EFI No start.
Old Dec 31, 2017 | 04:51 PM
sodbuster87's Avatar
Default Arctic Cat 2017 500 EFI No start.
2017 Arctic Cat 500 Efi. Started hard today. Left idle to warm up walked in house came out it was not running and when I went to restart it the fuel pump wont prime the winch is dead and the dash is dead. Also had a small antifreeze leak under left front side.. Temp was -15 today. It is going into. Shop Wednesday for something else. now it is going in for repair but it is going to bug me until then. Has good compression no banging or clanking. Spins over 100 miles an.hour but only when brake is squeezed. Even with trans in "park". Blown fuse? What caused it to blow. Also where is antifreeze coming from? Engine never even got hot enough to melt the frost of the block. It only has about 40 hours on it. Dash comes on for a few seconds when starter is engaged. Also it is showing no codes of any kind when the dash does come on. Any help appreciated, Sod Buster.
Old Dec 31, 2017 | 06:37 PM
So went out and checked all the fuses in the box under seat all were good but when I hit the key to on everything works like its supposed to. Did not try to start it. Also the radiator hose on bottom left had a couple drops of antifreeze on the very end.
Old Jan 1, 2018 | 10:04 AM
Zrock's Avatar
Super Quad Patrol
their is a weep hole on the bottom of water pump that could be where your leak is.
phillyK
Feb 8, 2004 01:44 PM
BONER
Nov 11, 1999 08:45 AM
