Idle speed valve _c40. Code.
Old Jan 12, 2018 | 09:51 AM
Dondi M's Avatar
Default Idle speed valve _c40. Code.
So because of the extreme cold recently my 07 king quad 700cc fuel injection wouldn't start. I got a new battery but Some how it would not start still. Turned out i snapped my fuel pump fuse. After replacing it. I now have warning light and the code is idle valve speed. How do you fix that. I've tried the " place in diagnostic mode press throttle n hold turn key for 10. 15 seconds then turn key off n release throttle" but still the same. Any help would be great.
Old Jan 12, 2018 | 10:02 AM
Dondi M's Avatar
Default C40 code
I forgot to mention that since that has happened, it doesn't like to shift into gear . It seems maybe idling a little too high so it makes some gear clicking noises .
Old Sep 10, 2018 | 08:41 PM
B_dues's Avatar
Bump! My bike has the same problem as you're describing. Idling high and wont get into gear because of this issue. Also the engine code. Did you figure out the problem?
nostiks
Jun 29, 2017 05:18 PM
H300F
Feb 3, 2001 08:40 AM
