07 Polaris 500 sportsman idles good dies with throttle
Need help with my 2007 sportsman 500 I just did timing chain guides tentioner valves the whole 9 cranks and idles fine but if I touch the throttle it dies I have checked timing fuel pressure (35ish) and I'm stumped any help would be appreciated
35 psi is a tad on the low side as the manual shows 39 psi +/- 2 psi.May or may not be enough to matter. Check the grommet (Item #9)under the t-bap for any splits. If damaged it can cause problems by sucking in air. Plus check the connectors and the wiring from the t-bap and tps sensor for any bare spots or soft feeling wires from internal melting.Several things could be causing this problem and best to have the manual and go through the trouble shooting checks to help narrow it down.Plus if it's not throwing codes this makes it a little bit harder to track down.2007 Polaris Sportsman 500 EFI Service Manual PDF Download Even a short in the etc switch could cause one to die. Just go through the electrical checks and efi checks and tests. Sensors were usually not a problem area but wiring and connectors were.
The manual can still help you narrow things down. Go through the electrical and efi check list and it can save you time and frustration.Just too may things on efi machines that could be causing the problem.Plus the most common problems we had were the tbap wiring harness and connectors. That along with an occasional tps harness. Not the sensors themselves. Look above in the Polaris expert section "sticky" on 700/800 efi problems. This applies to most all efi machines including your 500.A member started offering better harness repair kits than what I had from Polaris that kept failing.This can be one of the reasons or the main reason for the back firing and dying.This was another common symptom of a t-bap wiring harness short.https://otbpowersports.com/products/
BAMBAM11336
Jul 20, 2013 12:52 AM
mxXXrider88
Oct 20, 2011 06:38 PM
loranimal
Sep 19, 2011 07:12 PM
