how to remove shaft from inside rear cv joint
Old Jan 30, 2018 | 06:58 PM
whateverworks's Avatar
Default how to remove shaft from inside rear cv joint
all how to vids on you tube show a c clip in a groove in the inner rear cv joint. mine has no groove or c clip?
Old Jan 30, 2018 | 07:59 PM
Older models have a clip on the end of the shaft that you just had to knock on the cv joint to remove the cv from the shaft. On assembly you used a dead blow hammer or a block of wood and hammer to reseat it. Later models had a small snap ring that you had to pry open and then tap the cv joint off. To reassemble you had to open the snap ring back up to insert the shaft.
Attached Thumbnails how to remove shaft from inside rear cv joint-snapringcvhousing.jpg
Old Jan 31, 2018 | 07:27 AM
Is it possible then that mine would be the older style even though its a 2008? its a browning edition if that matters. tks.
Old Jan 31, 2018 | 07:45 AM
2008 500(if that's what you have) shows a plain circlip on the wheel end cv joint and the spread apart snap ring on the plunging joint side for the rear drive shafts. Front drive shafts just have the circlip,you should be able to knock the cv off the shaft.
Attached Thumbnails how to remove shaft from inside rear cv joint-62222583598d7af361b6b7e61be64f07f8f0479a.png   how to remove shaft from inside rear cv joint-21200ebd698097b750692dd61dd67d1f1e8cdd01.png
Old Jan 31, 2018 | 08:01 AM
Default rear wheel. Left side inner cv joint
Old Jan 31, 2018 | 09:02 AM
Rear left wheel. Inner cv joint
Attached Thumbnails how to remove shaft from inside rear cv joint-img_0874.jpg
Old Jan 31, 2018 | 10:11 AM
You've got one in there on the shaft that locks in a recess on the cv cage. See if this video helps. Look starting at the 3:00 mark.
Old Jan 31, 2018 | 12:58 PM
This is what I found on the inner rear cv joint
Attached Thumbnails how to remove shaft from inside rear cv joint-img_0875.jpg
Old Jan 31, 2018 | 01:00 PM
Now the issue is getting the boot clamps done up. Is it possible without the correct pliers? If not, will regular hose clamps work? Tks again.
Old Jan 31, 2018 | 01:44 PM
Make sure when you reassemble the cage,bearings into the cv housing, that the circlip locks into the cage firmly and can't easily pull out.Most say to replace the circlip,but if undamaged I've reused them. If you're using oem style clamps once you use a pair of earless type clamp pliers you'd cuss needle nose pliers,channel locks,etc.Plus 9 times out of 10 you'll destroy the clamps. Good addition to any tool box and not that expensive. Same goes for the ear type clamp pliers for tha style of clamp. Most auto stores have them hanging up.Sears.com
Lrdchaos
Feb 20, 2018 02:36 AM
cornermike
Feb 20, 2018 02:35 AM
PolarisO5
Dec 18, 2017 01:04 PM
filthyhabit
Jan 27, 2003 01:57 AM
