Miriad of problems 2002 scrambler 4x4 500
So it starts with no awd. All the dash lights were cracked. Burnt out. I replaced all of the lights with known working ones. I have traced it back to the transmission switch/gear sensor. I’m not getting any power to it. I don’t have a year specific diagram. Anyone have any idea which wire sends juice to the trans switch.
Should be getting power to the red/white wire from the transmission switch.If not you can trace back to see where the problem is or jump the gray/white wire from the switch to a good red/white that's powered up with the key on.That should power to the awd. Service manual like jumbofrank mentioned is best as you can see where the wires branch off in the wiring schematic. Can help trace shorts or grounding problems.2002 Polaris Scrambler 500 Service Manual PDF Download
Polaris5004x4
Apr 12, 2014 01:21 PM
SCRAMBLERMAN97
Jun 28, 2003 05:59 PM
bigblock
Sep 11, 2001 07:57 AM
