milky stuff in my engine
Old Mar 26, 2018 | 05:11 PM
nlb25's Avatar
Default milky stuff in my engine
I have a 2006 Kawasaki bayou 250. I went to change my oil and when I took the oil cap off I noticed a milky substance in the cap and in the engine. Could anyone tell me what this means.
Old Mar 26, 2018 | 06:31 PM
You can get water or moisture in the engine from several different ways. Since it's air cooled,you can get water from the air box if you do a lot of driving in water,vent lines from the carb or tank plus on some you can get a little amount of water just from moisture in the air that the carb sucks in that can accumulate over time in the engine.That hopefully is all that it is.
Old Mar 27, 2018 | 02:24 AM
Not getting the engine hot causes the "Mayonnaise" effect. If you only do short runs or trickle about at low revs in a high gear, the engine doesn't get hot enough to vaporise condensation. Some engines are more prone to it than others, Honda 300s nearly always have mayo on the starter gears when you remove them to change a starter.
Old Mar 27, 2018 | 08:05 AM
Yes that's another way merryman. I like your "mayonnaise effect" description on this..
thanasi
Jul 30, 2019 05:46 PM
Eyeballsdeep
Mar 25, 2018 10:16 AM
Shan1jes
10
Mar 10, 2018 08:10 PM
Ben Vinson
Mar 7, 2018 10:11 AM
Eyeballsdeep
Mar 4, 2018 09:44 AM
