01 400ex popping on decel
Old May 1, 2018 | 04:58 PM
Brandon whitford's Avatar
Default 01 400ex popping on decel
Backfires on decel unless I keep the throttle open a little
Old May 1, 2018 | 07:48 PM
YamahaMoto's Avatar
Country Rider
Well my initial thought is carburetor (problems seem to always be carburetor lol). My best guess would be the carburetor isn't working properly. I think the carburetor is almost getting stuck and keeps letting gas through causing it to bog.
Does it accelerate fine?
Old May 2, 2018 | 04:06 AM
Works perfect other than backfires (pops) when I let off the throttle it goes pop pop pop pop when I let off the throttle to shift down
Old May 2, 2018 | 06:46 AM
YamahaMoto's Avatar
Country Rider
Hmm. Im still going to say carburetor is getting stuck
Old May 2, 2018 | 08:35 AM
WOuld it be the slide sticking? Or a float problem I’d like to make it stop backfiring
Old May 2, 2018 | 10:22 PM
Lt Granddad's Avatar
What upgrades are done to the bike or did you make any changes with exhaust or intake. That is usually a lean condition with the pilot jet or fuel mixture screw, since it doesn’t do it when throttle is still lightly applied.
Old May 3, 2018 | 03:49 AM
Has a slip on its bored out what should I try first
Old May 3, 2018 | 08:10 AM
Do you run an open air box and better filter too. You may find your fuel mixture screw and count the number of turns the screw spins in till it slightly seats could be 1 1/2 or 2. ( Don’t screw it in really tight) Whatever it is screw back out to that point and add a quarter turn to it and test ride. If you have to get past 3 turns you will need to go to the next larger pilot jet screw out to 1 1/2 turns as a starting point
Old May 3, 2018 | 11:08 AM
Ok I will try that and get back to you
Sandalland
Jul 19, 2008 08:00 PM
BUBFRider
Jan 27, 2006 07:43 PM
01Raptorblk
Oct 28, 2005 11:16 AM
crotchrocket69
Aug 9, 2004 04:06 AM
c400ex1234
Sep 6, 2000 08:16 PM
