330 magnum charging
Old May 13, 2018 | 01:55 PM
maron's Avatar
Default 330 magnum charging
My 2004 polaris 330 magnum doesn't charge the battery. I replaced the regulator and he stator tests ok with a continuity check. Any ideas?
Old May 17, 2018 | 10:36 PM
Yooper265's Avatar
Have you checked voltage across the battery with the engine revved up a little bit ? Should be over 13 volts ?
Old May 18, 2018 | 09:17 PM
maron's Avatar
The voltage doesn’t change when I rev the motor. It stays at around 12.4 v.
Old May 18, 2018 | 10:42 PM
Yooper265's Avatar
If the stator checks ok it's either the regulator { again } or the regulator ground or the red wire from regulator to battery is defective .
maron
May 13, 2018 01:35 PM
trouttracker
Aug 22, 2014 12:19 PM
Scott267839
Nov 13, 2010 07:42 AM
2bulls78
Aug 5, 2006 04:06 PM
Arrowhead
Aug 22, 2002 11:58 AM
