2013 Polaris Sportsman 500 HO no top end
Old May 17, 2018 | 10:52 AM
Crushabug's Avatar
Default 2013 Polaris Sportsman 500 HO no top end
Quad runs and starts etc fine. Can hit max RPMs. The top end speed is 30ish.
I have replaced springs and belt. Everything seems normal except no top end speed.
Old May 17, 2018 | 11:13 AM
DirtDevil101's Avatar
What I would do:
1) confirm good compression
2) after #1 checks out, pop the belt cover off, get the rear axel off the ground, start it, but it in gear and visually watch the primary/secondary clutches movement while on/off the gas...making sure both clutches are shifting out/in fully
Old May 18, 2018 | 06:52 AM
polman500's Avatar
Sounds like buttons gone in the secondary.
Old May 18, 2018 | 02:08 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
check the secondary clutch buttons unless it has a roller clutch. sounds like it is not shifting up and would be a secondary clutch issue
instagramfinggaz
Aug 14, 2016 03:15 PM
dfaircloth
Jul 18, 2016 02:09 PM
fosgate3
Jul 13, 2016 09:44 AM
MyDawg01
Apr 25, 2000 10:01 AM
Peeps
Mar 24, 2000 12:27 AM
