How to troubleshoot a 07 honda 400ex stator (no spark)
Old May 27, 2018 | 12:18 AM
jhorns's Avatar
Default How to troubleshoot a 07 honda 400ex stator (no spark)
Hello all,
My quad has just recently lost spark so I went online to by myself a new stator to fix that problem once I installed the new stator I noticed I still have no spark can anyone tell me what i need to check on the stator to make sure it isnt a dud or if I have to check anything else thanks
Old May 27, 2018 | 02:02 AM
It is far more likely to be CDI, coil, spark plug, regulator or wiring fault than stator. In fact most Hondas will run quite happily with a faulty stator, until the battery goes flat.
Old May 28, 2018 | 12:39 PM
jhorns's Avatar
Does the stator produce any voltage while trying to crank the motor so the spark is generated at the plug? I am getting no voltage to the CDI, does the CDI require any voltage to get spark?
Thanks
Old May 29, 2018 | 01:48 AM
I tend to work on utility quads so don't know the exact spec of the EX but most Hondas made before the fuel injection ECU system, had a strange hybrid CDI which was part AC and part DC, so the CDI could get power from either alternator or battery. Best thing to do is get a workshop manual and follow the ignition system tests in it.
The alternator will produce a voltage when being turned on the starter, but it can be quite small. I am working on an Eiger at the moment, AC type CDI, and the spec is 0.3v minimum from the ignition power coil of the stator.
hueby
1) Engine problems..
Aug 29, 2015 08:34 AM
H2Ohhh
Dec 10, 2010 11:47 PM
BaD04WarrioR
Jul 12, 2005 11:20 PM
SoulShifter
Dec 12, 2004 10:47 PM
Voodoothenoob
Jun 26, 2004 03:57 PM
