loss of electrical power
Old May 31, 2018 | 02:37 PM
swamper65's Avatar
Default loss of electrical power
2006 sportsman 500 HO EFI. I shut it off with the key , went back about 10 mins. later and no electrical power anywhere, no key on power, no winch. removed key switch and found that the only power to the key switch is on the yellow wire. its not good power though as its only 7.72VDC . I get the same voltage using the frame, engine block or battery neg. term. as my ground. The battery is fully charged, connections are shiny clean and wrench tight. ground connections to the engine block and frame have been verified with a load tester. current battery voltage is 12.53VDC. Thank you for your time
Old Jun 1, 2018 | 03:33 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
did you make sure the shut off is turned on or is there power to it? if so I think thee is a fusible link between the battery and switch near the battery area.
Old Jun 7, 2018 | 10:01 AM
swamper65's Avatar
I hadn't checked the kill switch as I figured it was after the key switch in the circuit. I will check that and look for a fusible link . thank you
Old Jun 7, 2018 | 06:21 PM
Powerranger262's Avatar
When mine did this, I replaced the kill switch, and was back in business.
If that doesn't do it, I would suspect the ecm.
Old Jun 7, 2018 | 06:26 PM
This is actually my post on my issue.
https://atvconnection.com/forums/pol...cm-issues.html
Myridge
May 7, 2018 10:39 AM
Jimbo333
May 7, 2018 03:32 AM
roundvalleyranch
Apr 20, 2018 06:36 PM
Ryan Mann
Apr 18, 2018 08:34 AM
RHYZAN
Apr 5, 2018 10:44 AM
