Battery Light flashing
Old Jun 2, 2018 | 01:24 PM
marcsteve74's Avatar
Default Battery Light flashing
My battery light started flashing it starts when I take off and then stops. it starts and rides perfect what does this mean is it normal? thanks for any feedback.
Old Jun 4, 2018 | 03:20 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
are you able to check the voltage while the light is on? should be in the mid 13 volt range. are you running any accessories that draw a lot of voltage?
Old Jun 4, 2018 | 03:22 PM
Do you mean check the battery while it's running and the battery should maintain 13.v? I am not running any accessories but i did put in a new ignition could that cause it?
Old Jun 5, 2018 | 03:58 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yes while it's running. if you hooked up something wrong maybe
Old Jun 5, 2018 | 05:21 PM
Default Found it
I tested it while it was running the voltage was 16v that told me It was the (voltage regulator rectifier) its on order now thanks for the tip I would have cooked my battery.
Old Jun 6, 2018 | 01:12 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
that's why you always check it while running. your welcome.
Big600twin
Nov 2, 2016 10:16 AM
elbrown
Sep 4, 2008 12:04 PM
Ramman1
Nov 15, 2007 09:30 PM
schmidthead74
Sep 30, 2007 03:56 PM
waderman
Sep 24, 2003 05:40 PM
