DVX 90cc 2008
Wondering if anyone could help. I have a 2008 90cc ATV. I got it running, but it will not stay running at idle after a minute of running it at normal driving. If I let it sit for a few minutes, it will start back up. If I try right after, it will not start at all. I took apart the carb and cleaned it. Put on a new fuel filter. Tried to bypass the shutoff for the gas by plugging the gas line staright to the fuel filter. It will still die after a minute of running, until I let it sit for a few minutes. Then it will start, run for a minute, but once I stop at idle it will die out again. I think it is getting starved of fuel, but I am not sure where else to go with it. The fuel filter is only ever half full, not sure if that is an issue.
Anyone have any idea on what to do. I have to be missing something. Thanks
I would start by replacing fuel hose with new. Try bypassing the fuel shut off it may have a bit of crap in it restricting flow. Try running without fuel cap vent may be plugged in the cap. If those do not work pull the carb apart and clean again making sure your float level is set properly. I would also check your float and make sure their are no signs of fuel in it and its actually floating.
CALL911
Mar 6, 2018 09:38 PM
QuadAddiction
Apr 30, 2005 08:20 PM
