01 BRP Ds650 oil change help!
Old Jul 25, 2018 | 11:11 AM
Dans_700sports's Avatar
Default 01 BRP Ds650 oil change help!
I have been told i need to bleed the oil filter when i changr the oil... can anyone help me with the procedure for this?
Old Jul 27, 2018 | 10:10 AM
Every time i post on this page as of late no one seems to be willing to help is this turning into a dead forum or what?
Old Sep 16, 2018 | 08:47 PM
brewbybill's Avatar
No, you shouldn't have to bleed the filter for an oil change.
Old Sep 19, 2018 | 10:26 AM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
https://atvconnection.com/forums/sea...archid=2792322
Right here you will find all of your oil change answers.
Old Sep 19, 2018 | 07:07 PM
Sstvo's Avatar
Ace’s link isn’t working.
What year is your ds? If it’s one of the later years with the relief/vent line they say you don’t need to bleed it. Mines a 2001, has the vent line and I still crack it loose and bleed it anyway. (just to be safe, it’s very simple)
To find out if yours has the vent line, follow the large braided oil line that leaves the bottom of the tank and connects to the case behind the cylinder, clutch side. If there is a tee fitting at this connection with a small (1/4” or so) line running back up to the tank, your ds has the vent, and bleeding should not be needed. If it is a straight connection without the tee fitting you need to crack and bleed the screw.
The bleed screw is located just beyond the oil filter. It has a large flat head end on it. You will need a large long flathead with a fairly thick end to crack it loose. It will be very tight, so you need a screwdriver with the right size end. I ground down the end of a flathead to make the head of the driver a tight fit with the head of the screw. Gently tap it into the head of the screw to get a tight fit and then I use chanel locks or vice grips on the handle of the screw driver to crack it loose. Ive heard others use a punch style impact, I just use what I got. Works everytime.
Remove the screw, pull the plug wires and crank the starter over until you see clean fresh oil coming out. Doesn’t take much turning. My last oil change I decided to put a small dab of never seize on the threads close to the head. Hoping this eases the removal of it next time but we’ll see. Maybe I’m wasting my time, I just see it as cheap insurance to bleed it each time even though I have the vent line.
Old Sep 20, 2018 | 11:45 AM
Thank you for that makes sense now.
Feb 13, 2018 02:15 PM
azsandrider
Mar 3, 2008 09:53 AM
legorider
Aug 20, 2005 08:58 PM
