Unknown atv (gy6 150) rear reverse gear box fluid/grease/sludge?
Old Jul 27, 2018 | 03:17 PM
Pezgoon's Avatar
Default Unknown atv (gy6 150) rear reverse gear box fluid/grease/sludge?
Hey there all so I picked up a super cheap Chinese ATV (obviously) with a gy6 150, the engine looks nothing like the newer gy6’s so I would put it at probably 10-15 years old, no idea what brand it is but anyways.
was going through changing all the fluids when I get to the rear hub/reverse gear box. I go to change the “fluid” in it expecting gear oil and I get the bolt out, nothing happens, I think well **** it’s dry, when all of a sudden it starts slowly pooping out this greenish, what I can only describe as) sludge.
I’m guessing because it’s open vented it was at one time gear oil and now the moisture has killed it and turned it to a sludge, I wasn’t sure if it’s grease or not though or if it is intact gear oil so I’m hoping maybe someone here can help or atleast convince me to get it out and just put gear oil in it lol. Pictures for assistance
This is the reverse hub/gearbox
This is the sludge
Old Jul 28, 2018 | 09:48 AM
Zrock's Avatar
Super Quad Patrol
I doubt it would be any type of grease as that would not get into the bearings when it was pumped in... Id put some solvent or similar in their spin the tires up to move it around and dump it and fill with some gear oil..
Old Aug 7, 2018 | 10:09 AM
Pezgoon's Avatar
Alright sounds good, any suggestions on how much to fill it? The drain plug is on top so it’s hard to tell as it’s not a fill until it drains out plug. It’s vented to the atmosphere though so if I put too much in will it really matter?
Old Mar 16, 2019 | 09:24 PM
Stevan Gonzolez's Avatar
Default Have the same issue help help
I’m
Originally Posted by Pezgoon
Hi I’m having the same issue. I need help the gear box did you figure out the oil type an an basically how to change it out. Plz help
Oil type
Old Mar 16, 2019 | 10:15 PM
Pezgoon's Avatar
Hi I’m having the same issue. I need help with the gear box did you figure out the oil type an an basically how to change it out. Plz help
Oil type
Yes i did, I drained out the “sludge” from the drain hold on the bottom of the gearbox, ran some clean gear fluid through it (literally just poured it through it trying to rinse out some of the stuff)
then refilled it to above the gears I believe? Just kinda winged it. Drove it for a bit (maybe a few miles worth) then drained and refilled again while hot
just used gear fluid from WalMart w75-90 weight or there abouts
Old Mar 30, 2019 | 08:10 AM
Redhawk54's Avatar
I just bought an atv for 100. I had no idea what it was now after searching I have found what it is. Its a Chinese quad with no plastics. I have the same rear axle as this. Did you get the reverse to work if so how?
Old Feb 10, 2020 | 03:17 PM
stephane morin's Avatar
I have the same atv gy6 150
as you. I would like to know if you would be able to tell me how I could do to find out how to order the left cover of the gear box? I made arrow red for cover
Old Jul 30, 2020 | 10:29 PM
Mark Goerlitz's Avatar
Default Found unit
Maybe this will help, I am working on a FUSHIN 150 with this axle. Trying to find a cable to connect to shift lever. I found this site showing that axle, don't know if it will help anyone but here it is: https://www.scootercatalog.com/atv-r...e-reverse.html
Old Jun 7, 2023 | 03:19 PM
proautomik@gmail.com's Avatar
Default Chinese atv axle
Any chance someone has found parts for this type of axle assembly
bilinvic
Dec 19, 2008 11:48 PM
moroccomole2004
Sep 10, 2007 07:47 PM
GIZMO035
Apr 17, 2007 11:10 PM
godIlove2ride
Feb 15, 2007 12:00 PM
GNXGuy
Jul 2, 2006 04:33 PM
