TRX 250 front brakes constantly rubbing
Old Aug 2, 2018 | 06:02 PM
SWFLMUD's Avatar
Default TRX 250 front brakes constantly rubbing
08 TRX 250 front calipers. Just put new pads on last set didn't seem to last long. I've done it a few times in past but this time with the wheels off the ground i rotate the tires and they do not freely spin. However they spin great without the brakes attached just to see if it was a bearing.
Anyway, i've searched but just cant find a proper way to clean calipers, replace pads and not have it rub on discs. I've taken it for a ride a few times but still constant. shouldn't the piston go in and out when you pull the handle???
I did learn one thing from youtube, sometime in the past i threw away the small shim that is supposed to be on the inside pad. Could this be all the issue???? Now i have to look at my TRX700XX to see if i did the same thing.
Thank you fellas, I'm usually fixing my Polaris Sportsmans, not my Hondas.
Old Aug 3, 2018 | 02:48 AM
I only work on TRX250s with drum brakes (Recon) but, no doubt yours are similar to 420s etc. The pistons can get sticky, in theory red rubber grease on the seal surfaces should cure this but means dismantling, so I usually go for just pressing the piston in, and pumping it back out, not so far it comes past the seal, then repeat until it moves easier. The sliders for the caliper also seize, more tricky as sometimes the whole thing is too corroded to free off, but remove the pads, re mount the caliper and knock it backwards and forwards along it's sliders. If there is a rubber blanking plug over one slider, remove it and stick some grease in the hole, then put the plug back in. If they stay sticky, remove the caliper from the sliders and emery the slider pins, re-grease and put back. The shims are anti-squeal and don't do much, so don't matter. The threaded pins that hold the pads also corrode. I always de-rust, and coat them with copper grease before fitting.
junkorama
Mar 16, 2009 09:00 AM
crashby
Jun 2, 2006 05:06 PM
Mudrunner79
Feb 3, 2004 02:17 PM
waderman
Sep 24, 2003 05:40 PM
