Honda TRX300 Stalling Out
Old Sep 14, 2018 | 04:14 PM
bobemartin's Avatar
Default Honda TRX300 Stalling Out
With the help of You Tube videos I replace the Carb on my Honda 300. Now to my current problem which may be related or not. I got the Carb adjusted and idling pretty good for an old hillbilly, but when I took it for a test drive thing didn't work out very good. When in neutral the old girl does -great, but when I put it in gear and engage the throttle the old girl stalls out. If I pull out real easy it continues to run, but will stall out if I speed up to fast
Thanks for any help.
Bob
Old Sep 14, 2018 | 07:08 PM
Chad913's Avatar
Bob
sounds like it’s lean. Check the spark plug color. If white then to lean. May need to up the jets. If it has a needle with a clip on it move it down and I believe that richens the fuel mixture. Sounds like it’s not getting fuel.
Old Sep 14, 2018 | 08:18 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Did you install china carb? I havnt had anyluck with them alot of them are made for serveral different model an not jetted right for all atv, IMO I would deeply clean old factory carb and installed good brand carb kit an try that an see how atv performs JMIHO.
Old Sep 16, 2018 | 10:19 AM
Liberty4u's Avatar
I agree with cleaning and using the old carb if it's not an original OE replacement. It definitely sounds like you're leaning out and it's a fuel delivery issue.
Old Sep 17, 2018 | 10:14 AM
bobemartin's Avatar
Ok guys had a little free time on my hand this morning so back to the garage I went. That was probably a mistake, LOL. Here is what i found with the spark plug, which tells me I may have a spark issue, which I thought I had resolved, but apparently not. Here we go. Before I replaced the carb I had put in a new plug. I pulled the plug as suggested to check the color. Here what I saw. No white, no gray, no brown, no black from oil, but I did found black powder like stuff covering the plug. I knew I had spark or it wouldn't start at all, but I got a new plug and did the ground thing on the block to look at the spark and it looks pretty weak to my eyes. So with the stalling and stopping and black powder on the plug I suspect the coil or CDI box. Any comments?
Thanks
fire1998
Aug 6, 2015 02:46 AM
stangant
Sep 18, 2011 09:12 PM
truck1199
Mar 30, 2003 06:58 AM
Boggin400
Mar 24, 2002 10:17 PM
yamahagye
Mar 6, 2001 05:51 PM
