05 Suzuki 50 carburetor
Old Oct 8, 2018 | 09:05 AM
jimmy125jr's Avatar
Default 05 Suzuki 50 carburetor
I just picked up for my daughter at garage sale .Ran it home about 3 miles was bogging down really bad then finally made it home and had no power the carb was pouring out gas. I took the carburetor off and did a clean then went to reinstall and I have two of the smaller tube connectors I do not know what hooks where??? I have a black one I believe is running out of the oil I thought was a vent but it is the right diameter to for one of these and another one that is detached all the way which is clear same diameter. It starts up and wants to run but still acting up. Without these attached. It blows a lot of white smoke more than I think it should out exhaust as well. One connector is on top of the carb the other on the bottom .Any help would be greatly appreciated thank you! The gas line and choke and all is hooked up right. The fuel will pour out the bottom one sometimes and other times it does not while running. If any other information is needed I can give it.
Old Oct 8, 2018 | 04:39 PM
untraceable's Avatar
Just bough an 06 KFX50 (same bike), Im of no help, but I did discover some service manuals today that may help your issue
https://www.manualslib.com/manual/1143199/Suzuki-Lt-A50.html?page=3#manual
https://www.cyclepedia.com/online-manuals/kawasaki-atv-motorcycle-online-manuals/suzuki-lt-a50-kawasaki-kfx50-atv-online-service-manual/
Old Oct 9, 2018 | 03:02 AM
Small, clear plastic goes underneath carb, and is overflow, it points downwards. Pipe from oil pump on engine goes onto a brass union. I think there is another vacuum pipe to the fuel tap. The LT50 has one of the most awkward float assemblies to get right, as you can alter the float level by heavy handedness when cleaning the carb out. Most Suzukis have a run and a prime position on the fuel tap, it should always be on RUN except when filling an empty carb afer running out of fuel or cleaning carb.
Old Oct 9, 2018 | 04:50 AM
jimmy125jr's Avatar
Thank you I will try that this evening! That is probably why the gas was flowing out then is I didn't know to leave the gas in the on position.
Matthew Rankin
Jun 21, 2012 10:24 PM
KILLER_K
Dec 5, 2010 04:01 PM
bill
Nov 28, 2010 08:35 PM
Kwight
Nov 15, 2006 12:37 AM
rheemac
May 19, 2006 02:47 PM
