2002 kawasaki kvf 360 belt light will not reset limp mode help
Old Oct 16, 2018 | 04:50 PM
jazz7732's Avatar
Default 2002 kawasaki kvf 360 belt light will not reset limp mode help
brought kvf 360 in limp mode tried to reset but will not what would cause it not to reset belt switch is fine also connected to charger so good voltage was thinking of buying new speed sensor or replacement cdi any ideas before start chucking parts at it thank you
Old Oct 17, 2018 | 02:04 AM
Never worked on the belt drive Kawasakis, but someone on here had the same problem on a 700 and fitted a Dynatec CDI, which cured it. https://atvconnection.com/forums/kaw...e-700-4x4.html
Old Oct 17, 2018 | 02:25 AM
jazz7732's Avatar
I was thinking of this route but unsure if they make on suitable for the 360 it's a 2002 with one single large connector plug most of them have 2 plugs I think I'm going to wait for speed sensor turn up from China and see what happens thanks for the reply open to any other suggestions
Old Oct 17, 2018 | 03:31 AM
jazz7732's Avatar
also the speedometer is missing do you think it could be the cause
dilogdp
Mar 17, 2011 01:28 PM
750reasons
Jun 14, 2007 01:19 AM
hindtit
Jan 30, 2005 02:21 PM
