2002 kawasaki kvf 360 belt light will not reset limp mode help
brought kvf 360 in limp mode tried to reset but will not what would cause it not to reset belt switch is fine also connected to charger so good voltage was thinking of buying new speed sensor or replacement cdi any ideas before start chucking parts at it thank you
Never worked on the belt drive Kawasakis, but someone on here had the same problem on a 700 and fitted a Dynatec CDI, which cured it. https://atvconnection.com/forums/kaw...e-700-4x4.html
I was thinking of this route but unsure if they make on suitable for the 360 it's a 2002 with one single large connector plug most of them have 2 plugs I think I'm going to wait for speed sensor turn up from China and see what happens thanks for the reply open to any other suggestions
BigMtnRider
Aug 5, 2003 02:05 PM
