Kymco
Old Dec 9, 2018 | 11:50 AM
phedrick03's Avatar
Default Kymco
2013 Kymco 500I 4wd
my front wheels keep locking up in 2wd back wheel just spin
I have to use 4wd to get bike to move not the brakes I blead and changed them already
Old Dec 9, 2018 | 12:40 PM
Kymco 450i's Avatar
Need more info...is it the brakes locking up or the diff locking up?? In either case, if it is the brakes then calipers need rebuild or replaced, if front diff is locking sounds like moisture/rust might be in there. A complete drain and flush of the front diff would be a place to start
Old Dec 9, 2018 | 01:43 PM
phedrick03's Avatar
Default 2013 kymco
I have check the brakes and even bled them off to the point they are not working and still it is locking up on the frontend it will drive in 4wd but it is very bogged down
Old Dec 9, 2018 | 01:50 PM
Kymco 450i's Avatar
Still need to know if it is the brake pads locking up!! If it is then the calipers are probably bad and need replaced. You need to define the problem before it can be solved!
Old Dec 9, 2018 | 02:02 PM
phedrick03's Avatar
I look and the brakes are not locking up, the front wheels just stop turning
I jacked it up and even in neutral cant spin them
Old Dec 9, 2018 | 05:55 PM
Kymco 450i's Avatar
Brakes have nothing to do with neutral. Either the front diff is locking up or the brake pads/ calipers are locked up...need to determine which one or both!!
ichversuchte
1) Engine problems..
Aug 10, 2018 08:01 PM
check
Jul 10, 2007 10:06 AM
onreserve
Feb 17, 2006 04:38 AM
eton150
Jun 30, 2005 08:35 PM
Jeff1216
Jun 13, 2005 02:02 PM
