2003 LT80 won't run - help
Original problem was no compression. Replaced piston, rings, cylinder board oversize and new carboretor. Installed all new gaskets including crackshaft seals.
Then had no spark so I replaced CDI unit, ignition charging coil, ignition coil and emergency brake switch.
Now I have spark but motor will not run.
Cylinder leak down testing showed good results as well as compression testing.
Carboretor and fuel petcock valve are aftermarket. Could this be the problem?
When spark plug is removed it is wet, getting fuel.
Any ideas on what could be the issue?
