2016 Coolster 125cc irratic starting
Old Jan 7, 2019 | 07:09 PM
tomcrockettsr's Avatar
Default 2016 Coolster 125cc irratic starting
Inquiring about starting on our 125cc Coolster. New Coil, new Carb, fresh gas... Unit will turn over , shows good spark and fuel delivery.
Will not start unless jumped from another vehicle.???
Old Jan 8, 2019 | 02:26 AM
Fit a new plug, next set the valve clearances. If it is still bad to start check compression, under 90psi and you need to remove the head and cylinder, and start measuring ring, bore, and piston wear, and valves and seats for pitting and burning.
Old Jan 9, 2019 | 05:45 PM
Default Coolster Not starting good
Thanks for the quick reply. This will give me something to go on...
Old Jan 10, 2019 | 03:03 AM
Re-reading your post, it could be a bad battery or connection, does the engine seem to turn slowly if you try to start it without the jump leads?
Old Jan 10, 2019 | 09:13 AM
Zrock's Avatar
Super Quad Patrol
ya i was going to say battery. The little battery's in these toys are just enough so when they start going bad it does not take much. When is the last time you had the battery on a maintainer?
puggerton03
Jul 3, 2017 04:50 AM
russl
Aug 29, 2016 09:29 PM
IB Cristina
Newsletter Archive
Jan 26, 2016 07:00 PM
tbsleeper
Jul 10, 2004 01:12 AM
Marshman5300
Nov 27, 2003 02:37 AM
