1994 Honda Fourtrax spits and sputters
Old Jan 31, 2019 | 03:28 PM
Cole5065's Avatar
Default 1994 Honda Fourtrax spits and sputters
My Honda Fourtrax spits and sputters after about quarter throttle and I’ve cleanes the carb topmto bottom blew out all the jets and put back together and still can’t find out why, has a new spark plug but just sputters and gets almost no power when sputtering please help
Old Feb 1, 2019 | 02:39 AM
I have had a faulty CDI do this, but you must be very, very sure it isn't a carb problem before going to the expense of a new CDI. I tried another carb first, and only when that didn't cure the fault did I try a new CDI. Also, Honda changed CDI type about every three years on the 300, and they all look identical (except the last one) but have different coloured wiring plugs, get the wrong one for your year, and it won't work properly. It may be worth checking if the regulator is overcharging before anything else, as over 14.5v at the battery, can upset the CDI.
Old Feb 1, 2019 | 09:30 AM
LT80's Avatar
LT80 Expert
Compression? (wore piston)
makememad94
Aug 16, 2010 05:59 PM
greenyswatter
Apr 17, 2006 12:13 AM
Blknbluewarrior
Oct 15, 2003 09:55 PM
Kuntry
Aug 8, 2001 06:17 PM
