Raptor plastic question?????
Old Apr 24, 2001 | 02:17 PM
Need4Speed660R's Avatar
Someone told me that white plastic tends to turn yellow. Is this true, and why. What can be done to prevent it from happenning. This is 1st quad with white plastic. Thanks for the help.
Old Apr 25, 2001 | 12:16 AM
Wow!!!! 43 views and not a single reply. Either no ones heard of this problem, or there is no cure for it. Somebody must know something.
Old Apr 25, 2001 | 12:30 AM
brokemybanshee's Avatar
I wouldnt be worried about it, I think the yellow is from wiping the mud off the fenders after a long time and it gets worn into the plastic, if you rinse it down with a hose before going to it with the towel it should be all set.. White plastic is great, no stress marks, dosent show scratches, and when it gets bad you can sand it down an shine it back up like new. Also armorall or that 2001 stuff works good, whichever has the UV-block in it..
Old Apr 25, 2001 | 12:55 AM
doolin64's Avatar
I thought the only time when white plastic turns yellow is when the plastic is located near the gas tank. Which happens obviously because of the gas.
Old Apr 25, 2001 | 08:51 AM
Klemvore's Avatar
gas and oil along with the sun will turn the plastic yellow.. if your quad needs a bath give it one and if it shows yellow.. soft scrub should do the job of turning it white again.. good luck
Firefighter400
Oct 8, 2022 06:38 PM
toonces
Aug 5, 2015 05:55 PM
black_thunder
Jul 22, 2015 06:01 PM
toonces
Jul 11, 2015 12:01 PM
yambam13
Jul 4, 2015 01:49 PM
