Instructions on a Warn Winch????
Hey Kodiak,
My computer has been down so I could not respond earlier....
The instructions are great. Thank you for taking the time and sending them.
I have one more question.....
Where is a good place to splice the wire for the solenoid.
Thanks for the help!
Connections:
The 72" Red wire must be cut into two sections. One section will run from the toggle switch to the solenoid. This wire must have the eyelet on one end. The other section will run from the toggle switch to the ignition wire located in the front area of the bike near the steering post.Look underneath the plastic shroud facing forward on the bike.
After determining the proper length of the two sections of red wire, the section running from the toggle to the solenoid must have a eyelet terminal on one end and a spade lug must be installed on the other end. The other piece of red wire running from the toggle switch to the ignition wire must have a spade lug installed at one end and must be spliced into the ignition wire at the other end.
You may choose to place the toggle switch in a location that is convenient for you. The solenoid should be located back near the battery of the bike. Hope this helps.....
....L8tr kodiac...
....L8tr kodiac...
This info may be a little late, but you don't need to splice the solenoid wire into the ignition wire. If you pull the "dash" off the handle bars and simply unplug the brown ignition wire, then strip enough of the casing off the red wire from the solenoid to insert it into the plug in connection, and then plug the wires back together it works great.
Rick
Rick
Jeff Roper
Feb 1, 2022 11:48 AM
