Instructions on a Warn Winch????
Old Apr 24, 2001 | 02:59 PM
bukhunter's Avatar
Does anyone have installation instructions on a 2000 lbs Warn Winch.
I lost mine and have no clue on how to install it.
Thanks
Old Apr 24, 2001 | 05:18 PM
FKNA's Avatar
Shoot me an e-mail. I may still have mine at home somewhere.
Old Apr 24, 2001 | 08:27 PM
kodiac's Avatar
Hey bukhunter.....It's should be in your e-mail by now.....scanned it about an hour ago.
L8tr....kodiac
Old Apr 26, 2001 | 03:16 PM
bukhunter's Avatar
Hey Kodiak,
My computer has been down so I could not respond earlier....
The instructions are great. Thank you for taking the time and sending them.
I have one more question.....
Where is a good place to splice the wire for the solenoid.
Thanks for the help!
Old Apr 26, 2001 | 06:13 PM
kodiac's Avatar
Connections:
The 72" Red wire must be cut into two sections. One section will run from the toggle switch to the solenoid. This wire must have the eyelet on one end. The other section will run from the toggle switch to the ignition wire located in the front area of the bike near the steering post.Look underneath the plastic shroud facing forward on the bike.
After determining the proper length of the two sections of red wire, the section running from the toggle to the solenoid must have a eyelet terminal on one end and a spade lug must be installed on the other end. The other piece of red wire running from the toggle switch to the ignition wire must have a spade lug installed at one end and must be spliced into the ignition wire at the other end.
You may choose to place the toggle switch in a location that is convenient for you. The solenoid should be located back near the battery of the bike. Hope this helps.....
....L8tr kodiac...
Old Apr 27, 2001 | 04:38 PM
bukhunter's Avatar
Thanks for the help kodiak!!!
Old Apr 29, 2001 | 02:39 AM
GrizRick's Avatar
This info may be a little late, but you don't need to splice the solenoid wire into the ignition wire. If you pull the "dash" off the handle bars and simply unplug the brown ignition wire, then strip enough of the casing off the red wire from the solenoid to insert it into the plug in connection, and then plug the wires back together it works great.
Rick
Jeff Roper
Feb 1, 2022 11:48 AM
Johnny Mac
Aug 15, 2019 03:13 PM
panicmanic
Sep 28, 2015 12:59 PM
cboler9
Sep 24, 2015 08:35 PM
chewy78
Sep 8, 2015 10:37 AM
