Strange issue
Old May 28, 2019 | 09:25 AM
ranferg's Avatar
Default Strange issue
I have a 2011 Sportsman 850. Every once in a while the check engine light comes on and it will idle but won't rev up enough to even move. I have discovered that if I can get it rolling and cycle the 4wd switch from 2wd to any 4wd and back the light will go out and it runs just fine. Has anyone ever encountered this or even know what might be causing this? Thanks.
Old Jun 3, 2019 | 06:00 PM
ranferg's Avatar
Default strange issue
257 looks and no replies? Is this issue that strange? I know it's pretty bizarre to me. Don't even know where to start looking for the cause of this!
Old Jun 4, 2019 | 11:33 PM
Big Frank's Avatar
THE BERMINATOR
Veteran: Army
5 Year Member
Here's one more look. That really is strange. I've never heard of anything like that and can't imagine what would cause it.
Old Jun 5, 2019 | 06:20 AM
Kymco 450i's Avatar
Sounds like you have an electrical glitch......best I can do!
Old Jun 5, 2019 | 11:41 AM
pigseye's Avatar
This is very strange. I'm not an expert but I agree that this is an electrical issue. Might want to start by confirming grounds are good and then start walking through all the wiring that resolves the problem to see if there are any shorts to ground or across different wires. I would start looking where wires have a potential of being very warm, near vibration, or is being flexed.
Please keep us posted.
Old Jun 7, 2019 | 01:00 AM
Big Frank's Avatar
THE BERMINATOR
Veteran: Army
5 Year Member
Gremlins. That's all I can think of. Gremlins.
P.S. There's a lot of twisting back and forth of the wiring around the handlebar area and under the headlight pod. Something may have worn through and shorted out but you already know what I think it was. Electrical problems are the worst.
Old Jun 24, 2019 | 07:32 PM
TFW's Avatar
TFW
Default Strange Stuff.
By (Fixing your problem temporarily) it might be dirty contacts in some switch. Just a guess l have had no start problems with a 2009 Sportsman 800 and it turned out it was the the handlebar kill switch was cruddy.
Tom Wecas in WY
ripperoo
8
Apr 28, 2014 06:08 PM
beergut
Aug 25, 2010 06:09 PM
MolokaiRider
Jul 8, 2008 06:21 PM
Ljh815
Jan 12, 2008 06:19 PM
Treacherous
Aug 21, 2004 07:43 AM
