400 carb on a 250???
Old Dec 16, 2003 | 07:10 PM
Jayblazer's Avatar
Default 400 carb on a 250???
a guy will give me a carb off of a 99 scrambler 400 would this work good on my trailblazer 250??
Old Dec 16, 2003 | 07:26 PM
x_scrambler3's Avatar
Yes it will work in the trailblazer an it will give you alittle more power. It hard to get into the intake boot but can be done. You will need to rejet it.
Old Dec 16, 2003 | 10:12 PM
2manytoys's Avatar
First thing is do you have any mods? This will help determine the main jetting. I have run the 34mm carb for a while on my moded TB and it did give more power but it will never have the response of a flatside carb. You can also use your stock airbox and intake manifold. The best way to put the bigger carb is to make sure it ( the boot) is not cold, then use dish soap. The best lubricant for rubber. It should slide on fairly easy. If you do not have any mods then the main jet should be around 150-160. Keep everything else the same. You just have to adjust the needle and airscrew. Just keep an eye on the color of your plug. This should get you close but if you have mods then each mod will change the jetting. Let me know what you have and I can help you get close. Also you need the brass choke fitting from the 400 to work. If you do not have this the choke wont work. The fitting from the 30 mm is different and will not adapt to the 34mm carb. But everything else is the same. Good luck!
Old Dec 16, 2003 | 10:15 PM
Jayblazer's Avatar
what kind of gains would you say i will get? i have an rcr stage 1 kit. do you think it is worth doing just for trail riding? how will it affect the reliability of the motor?
wow 2many you snuck that post in on me the carb still has the chock cable on it so would the brass piece be in there?
Old Dec 16, 2003 | 10:25 PM
2manytoys's Avatar
You will gain better bottom end and slightly more top end speed. Throttle response will be better than the 30mm but wont be instant response like the flatside carb. If jetted right it will not make the quad any less reliable. It is a decent upgrade. How do you like your RCR kit?
Old Dec 16, 2003 | 10:51 PM
Jayblazer's Avatar
thanks for the input truthfully i dont have the rcr kit on yet i am getting it for x-mas its just sitting in a box calling to me i am kind of worried about putting it in now because of the jetting, it is so cold around here i am sure my jetting would be off and i dont want to hurt the piston i may just stay stock till spring then put the rcr kit and carb in at the same time so i only have to mess with jetting once.
if you cant tell jetting the carb scares me i see people haveing probs with it all over the forum
my only hope for getting it all done right is guys like you thanks..
Old Feb 4, 2004 | 07:53 PM
baxy's Avatar
how do you remove the needle jet??
also I have a 6DH29 needle in my 400 carb .... should I try this when I put it on my xplorer 250 ??
the used 400 carb I bought came with 200 main,6DH29 needle,#30 pilot
hopefully someone can let me know how the needle jet comes out before I bust the thing.
Old Jun 23, 2019 | 11:02 PM
Marc Allan Mallory's Avatar
Default 98 250 trail boss .060
have a 1998 trailboss 250 bored over .060 if I run the vm34 would I have to re jet?
Old Jun 25, 2019 | 08:59 AM
scootergptx's Avatar
Supersock
Hired Gun!
Since this is a really old thread, you may want to start a new one. Probably get a few more views that way.
Simple answer would be yes, but couldn't tell you what jets to use.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
