What size rings do I need if my piston is 90.46 Honda foreman 450
Old Jun 2, 2019 | 09:54 PM
Zdwilliams14's Avatar
Default What size rings do I need if my piston is 90.46 Honda foreman 450
Is it bored over .20?
Old Jun 3, 2019 | 02:07 AM
Standard bore is 90mm so it is 0.5mm overbored. Don't rely too heavily on a vernier measurement for checking though, micrometers are a lot more accurate when you get about 100mm sizes to measure.
Old Jun 3, 2019 | 11:55 AM
So the 90mm rings I have won’t work I need to get bigger ones. Or should I just get a whole new rebuilt kit
Old Jun 4, 2019 | 01:10 AM
Depends on the state of the piston and bore. If the bore is scored or worn more than 0.01mm, (usually worst at about 15mm below the top), you need a rebore and bigger piston to suit the new bore size. If the bore is OK but the piston is worn to less than 90.46mm, you need a new piston of the same size (0.5). If both are OK you just need 0.5 oversize rings.
440EX026
Mar 1, 2005 11:06 PM
