Turn key on...nothing.
Old Jul 11, 2019 | 11:24 AM
02Tbird's Avatar
Default Turn key on...nothing.
I have been a member here for many years. Have not been on in a long time, we changed our email address and I forgot my password, so I resigned up. We are going to start riding a lot more than in the past so I rejoined.
I have a Polaris X2(20007) 800 Sportsman.
I was charging the battery with a battery tender and tried to start it and it did crank over and then quickly quit. Now when I turn the key on, nothing no power.
I checked all the fuses in the fuse box under the front cover.
Is there a main fuse somewhere else? What else could it be.
Old Jul 11, 2019 | 08:18 PM
Kymco 450i's Avatar
Battery may be shot, they sometimes get internal shorts and will show a good charge but it is only a surface charge. Get a load test on the battery or just try another battery from a friend. Jumping may not work if the battery has a short internally. Just a suggestion, have had the same issue in rhe past.
Old Jul 11, 2019 | 08:23 PM
02Tbird's Avatar
Thanks for the tip.
I went out tonight to push it up on my trailer to take in to have fixed. I decided to look to make sure the connections on the battery were tight. The positive connection was very loose.
The battery was new at the first of the year. I have started and driven that thing 8-10 times this year, but all of a sudden the positive cable is very loose, strange.
I tightened it and it started and ran fine.
Thanks for the tips.
Last year the kill switch went bad. I could play with it and get it to work, but I had that fixed as well.
Old Jul 11, 2019 | 09:20 PM
Kymco 450i's Avatar
Yep, I should have added loose connections in my suggestions! Glad you have it sorted out....
Old Jul 12, 2019 | 01:10 PM
02Tbird's Avatar
thanks
duckdawg
Oct 27, 2021 01:42 PM
whitey123
May 26, 2017 02:57 AM
project_grim
11
Jul 16, 2013 05:38 PM
wildirishman
Sep 20, 2009 07:43 PM
