Newbie needs help
Old Jan 26, 2020 | 01:40 PM
blaz4wd's Avatar
Default Newbie needs help
Afternoon everyone, I have been using the site for reference/trial and error but I can’t get this figured out. Rig. 94 Polaris big boss 400l 6x6.
Back story is I bought this a year ago. When I got it running we had the antifreeze shooting out of the overflow tank. So replaced head gasket. Took it out to the farm ran it around and decided to run it a litter hard. Ended up bogged down and white smoke(aka antifreeze getting in cylinder) so again replaced head gasket.( bled air out of system, torqued down head again after cool down) Months down the road... plow the drive a couple times. So I took it out is fishing with the boy. During the run to the register the fish across lake I noticed smoke trail.. so bought used head from Polaris dealer head gasket 3 went in. At that time I had some welding to do on the exhaust and saw the smoke again.(ok antifreeze got into the muffler etc) so I took the acetylene torch and heated it up till the smoke disappeared. So to cut the story even shorter is that I bought a rebuilt jug installed that and put original head on ran for a few died. Fouled out by antifreeze. So off again and put used head(dealer bought)with new gasket. Runs but will foul out again same symptoms. Burn the plug off with propane torch runs for a bit dies.
sorry for the long description. But some how I keep throwing cash away and running out of options chasing down this antifreeze getting into jug. Thanks Joe
Old Jan 29, 2020 | 10:28 AM
pigseye's Avatar
Do you have antifreeze in the counter balance oil? Maybe the seals on the water pump shaft are shot.
Old Jan 31, 2020 | 03:16 PM
blaz4wd's Avatar
No milky oil in there still nice and clear.
Old Jan 31, 2020 | 05:32 PM
pigseye's Avatar
Default Latebird or other experts, Could you please help here?
Very weird. I don't know why you would have repeated head gaskets blowing out unless it is over heating. Some questions:
  1. Does the red over heat light work? Apply 12V to find out. Be careful of polarity.
  2. Does the fan work? Can you apply 12 volts to confirm it works?
  3. Do the heat sensors work at the top of the cylinder and at the radiator? Could you take them out and put them in hot water to see if the are functioning?
  4. Is the radiator clogged? Do you know if coolant is actually flowing through it?
  5. Is the water pump working?
Issues in any of these areas could cause over heating which could lead to head gasket problems. I ask question number 1 because I had LEDs go bad on my 1995 Xplorer and had to replace them. I did apply 12 volts to the red over heat light and it worked fine so I am good there.
Hopefully other experts will see this and weigh in.
greasemonkeyjmj
Apr 28, 2020 08:16 PM
AlwaysBroken
Jul 4, 2008 09:30 PM
needaR
May 19, 2004 07:59 PM
fastasyoucango
Dec 1, 2003 12:06 PM
Sanddude
Nov 7, 2000 06:50 PM
