No power at the key
I've got a Polaris 500 sportsman. It's a 2004. I have power from the starter solenoid to the ECM. From the ECM to the speedometer. Nothing after that. The ECM and speedometer are new. I can't get anything to the ignition switch. There is no power to the junction box either. I'm in serious need of help!!!!
The solenoid could be the problem. Take screwdriver with a wooden or rubber handle and touch the two terminals together. It should spark a little and power everything and it will also start turning the starter. If that doesn’t work then try replacing the solenoid. Hope that’s helps.
seibert77
Oct 26, 2012 10:19 AM
